Check oil light
Fairly typical symptoms, you likely either have a broken oil pump or a walked cam bearing. Your tick might actually be a result of the low oil pressure. Either way the oil pan and front cover have to come off. The fact the light goes out when you rev the engine suggest the switch or wiring is not faulty.
now to try to put things in the dishwasher hahaha wife will kill me
I went with the wired one and mounted it between the gauge cluster and the driver's door - it fits perfectly on top of that little vent. Great piece of mind to be able to see your exact temps. I also like to use my phone for navigation on longer trips, and this avoids me having to dedicate the screen to monitoring temps. The wired UltraGauge is always on and it'll beep if I'm not paying attention and the temp gets too high. It also reads codes and can clear the Check Engine light.
Here's what I ordered:
1 x UltraGauge EM Plus v1.2 (UltraGauge_EM_Plus v1.2_15)
Mounting options Horizontal Surface Mount & Bracket
Good job. Using blue tooth on a cell phone never make sense to me. UG is 10x better and the location is fixed. Set it up and done. I used the suction cup to keep it up a little higher. Ultra Gauge is the best. Who wants to set up new BT and apps each time you get a new cell phone or fiddle with phone updates? Set it and forget it.
i agree I don’t even like touching my cell when I’m driving Here in Canada if they even suspect your looking at a cell you get rammed with a $1000 fine.
plus sometimes I don’t even have a cell phone when I drive
What the hell is going on in Canada, the more I see in the news the more I feel like we live next to the Soviet Union.
The following 2 users liked this post by Extinct:
Richard Gallant (05-04-2020),
Sixpack577 (05-04-2020)
95 % of the shootings happens in Toronto area with stolen hand guns.
We are losing our freedom
That Gun ban was a Knee Jerk Reaction ..... with no due process .... they are Terrified of what could happen to them. They over played there hand.
@redwhitekat Not without a large change to the law, firearms are a federal responsibility as Alberta was told by the Supreme Court when this mess started back in the 80's and they wanted to handle things provincially. But it is very off topic
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
