Yup and you cannot get it out on an 04/03 with out removing the valve cover in 90% of the cases, but carb cleaner sprayed down there 8 or 9 times will clean most of the goop out. Work wonders on mine an killed my oil consumption completely.
Thanks Richard, Anybody sell these?
Just finishing up on a cam and lifters on my 03/D2, looking at details as I reassemble..Thanks for the info,will try carb cleaner trick..JV
If your talking about the oil separator then just grab it with pliers and wiggle it out
I just did mine it's metal stud with a pin hole on top and inside it has a plastic oil separator
i drilled that plastic out and will be installing a fram pvc valve
