check Valve in right valve cover
Old Aug 15, 2018 | 11:40 PM
piperff's Avatar
Default check Valve in right valve cover
Needed, I assume this valve is part of the PCV system...mine is sooo stuck...disco 2 ..4.6
Old Aug 16, 2018 | 12:00 AM
Richard Gallant's Avatar
Yup and you cannot get it out on an 04/03 with out removing the valve cover in 90% of the cases, but carb cleaner sprayed down there 8 or 9 times will clean most of the goop out. Work wonders on mine an killed my oil consumption completely.
Old Aug 16, 2018 | 01:27 AM
piperff's Avatar
Thanks Richard, Anybody sell these?
Just finishing up on a cam and lifters on my 03/D2, looking at details as I reassemble..Thanks for the info,will try carb cleaner trick..JV
Old Aug 16, 2018 | 02:56 AM
JUKE179r's Avatar
Remove the ****ty plastic PCV, throw it away and screw in a FRAM FV308 PCV to the manifold cover.
Inline PCV - Best4x4
Old Aug 16, 2018 | 06:35 AM
redwhitekat's Avatar
If your talking about the oil separator then just grab it with pliers and wiggle it out
I just did mine it's metal stud with a pin hole on top and inside it has a plastic oil separator
i drilled that plastic out and will be installing a fram pvc valve
Old Aug 16, 2018 | 06:49 AM
Sixpack577's Avatar
I did Best4x4's Fram PCV valve too.
Old Aug 16, 2018 | 08:40 PM
Extinct's Avatar
Originally Posted by Sixpack577
+1
+4 No more oil leaks!
Old Aug 17, 2018 | 11:12 AM
Any pics of this mod ? Did you guys keep the metal fitting in and attached the new pcv or did you guys put the new fram pcv in the hole
Old Aug 17, 2018 | 11:20 AM
Best4x4's Avatar
Remove OEM plastic nipple from intake, screw in the FV308, and if you can remove the baffle from the valve cover for the best results.
Old Aug 17, 2018 | 12:13 PM
Oh I'm talking about the oil seperator mod with a new fram pcv
