check Valve in right valve cover
You should be able to grab the nipple with some plyers and yank it out, then tap the plastic baffle out & then re-install the nipple into the valve cover. Or worse case scenario remove valve cover completely to get it out.
The FV308 is a PCV. It replaces the straight thru nipple and puts a PCV into the system vs a plastic twirling piece of plastic. So you kill two birds with one stone. Replaces weak OEM plastic nipple & add’s a real PCV into the system without hacking anything up.
