check Valve in right valve cover
Old Aug 17, 2018 | 12:22 PM
Best4x4's Avatar
You should be able to grab the nipple with some plyers and yank it out, then tap the plastic baffle out & then re-install the nipple into the valve cover. Or worse case scenario remove valve cover completely to get it out.
Old Aug 17, 2018 | 12:33 PM
redwhitekat's Avatar
I did that already but I want to install a new fram pcv on that valve cover
Old Aug 17, 2018 | 12:39 PM
Best4x4's Avatar
You don’t need it at the valve cover. Use the FV308 attached to the intake and connected to the valve cover.
Old Aug 17, 2018 | 12:47 PM
Sixpack577's Avatar
Originally Posted by redwhitekat
Any pics of this mod ? Did you guys keep the metal fitting in and attached the new pcv or did you guys put the new fram pcv in the hole
Post #4
Old Aug 17, 2018 | 12:58 PM
I bought the fram pvc fv 237
Old Aug 17, 2018 | 01:19 PM
Best4x4's Avatar
I’d take it back & use the FV308 personally. No cutting the OEM hose, it replaces the weak plastic nipple with metal (upgrade #1), then it add’s it cleanly inline & looks 100% OEM.
Old Aug 17, 2018 | 01:38 PM
JUKE179r's Avatar
Oh I'm talking about the oil seperator mod with a new fram pcv
They were talking about the plastic PCV.
I’m working on adding an oil separator. Trying to sort out the tubing connections and routing for both sides of the engine and location of the separator.
Old Aug 17, 2018 | 01:41 PM
But that is just a fitting I'm talking about getting a better way to desperate oil in the pcv system
I'm getting slot of oil in the intake
Old Aug 17, 2018 | 01:56 PM
Best4x4's Avatar
The FV308 is a PCV. It replaces the straight thru nipple and puts a PCV into the system vs a plastic twirling piece of plastic. So you kill two birds with one stone. Replaces weak OEM plastic nipple & add’s a real PCV into the system without hacking anything up.
Old Aug 17, 2018 | 02:43 PM
Ohhhh I see
