checking transmission fluid..cold or hot?
Old Jan 24, 2011 | 12:55 PM
NiteTrain's Avatar
Default checking transmission fluid..cold or hot?
rave doesn't say which..i've checked it in the past and i believe it was hot..level was fine..I just checked it cold and fluid rushed out.
I'm guessing hot
Old Jan 24, 2011 | 01:11 PM
Jabez's Avatar
Default cold
I just had mine checked at the service dept and they said it should be checked cold.
Old Jan 24, 2011 | 02:14 PM
hilltoppersx's Avatar
i would check it cold. if fluid rushes out then you are full. are you checking because you have a leak?
Old Jan 24, 2011 | 02:18 PM
NiteTrain's Avatar
no leaks, but the last couple of times I started rover up while really cold it took a few seconds for rover to move..had to build up pressure in tranny
Old Jan 24, 2011 | 02:28 PM
humroot's Avatar
Don't you want to check it hot? Or I guess it really doesn't matter, hot or cold, but I think you need to run through the gears to get the fuid running through all the parts (torque converter) and check it while the engine is running. That's how I check mine.
Old Jan 24, 2011 | 03:15 PM
DiscoIIBrandon's Avatar
I'm no expert, but my D1 trans dip stick has the fill level for "check at cold idle". I would check at cold and after running through the gears once or twice, because that's what I've been told to do!
Old Jan 24, 2011 | 03:25 PM
ill get it hot if im going to change so it will drain easier. i'll like to hear what others say.
Old Jan 24, 2011 | 03:26 PM
that is correct. you should cycle thru the gears up and down and wait a few seconds at each then shut it down and check again.
Old Jan 24, 2011 | 03:31 PM
yloDiscoII's Avatar
X2 I've always gone with hot, or at least warm, and running, so the fluid isn't all settled, and you can get a more accurate reading.
Athana
Jun 8, 2019 10:23 AM
Externet
Oct 2, 2014 12:01 AM
DUBLJDISCO2
Jan 6, 2012 06:29 PM
nickd503
May 18, 2009 08:49 PM
jkid
Jan 26, 2008 08:11 PM
