Chevy Fan Clutch, works on a D2?
Old Jan 15, 2014 | 02:41 PM
99Discovery's Avatar
Default Chevy Fan Clutch, works on a D2?
Planning springtime maintenance. Part of that includes the fan clutch.
I've read a lot that a Chevy van clutch (non-ac) can work on the disco 1. Nothing about the disco 2. I'd imagine it'd work.
But, does it work AS WELL? Although cost is important, this is a Utah desert build, and will need to be able to keep up with low-speed high outside ambient temps.
If I go with the chevy clutch, will I need a new fan?
Or should I just go all "stock" and keep it maintained?
Part of the maintenance also includes radiator, hoses, etc, so I've already got that covered.
Thanks
Old Jan 15, 2014 | 05:13 PM
dusty1's Avatar
You will not need new fan with the van clutch. May have to enlarge bolt holes
Old Jan 15, 2014 | 06:43 PM
pinkytoe69's Avatar
If you are not getting a used/junkyard chevy one, you might as well get the correct one. Oreilly and Autozone sells them and they are only like $10-15 more expensive.
Old Jan 16, 2014 | 03:18 PM
Dane!'s Avatar
summit racing has an "extreme duty" new one for 50$, direct fit, I have it.
Old Jan 17, 2014 | 08:49 AM
Dane, thanks for the heads up. I'm assuming you mean the Hayden unit? Have you checked temps with the ultraguage, does it work any better, same? I'm just wondering if a severe-duty will overspeed the plastic fan..
Old Jan 19, 2014 | 01:07 PM
Dane!'s Avatar
I had bad fan clutch so I couldn't tell you the difference, I just know it sounds way difference compared to my old one, it was shot when I bought the truck.
bantham1
Jan 11, 2020 05:13 PM
MC04DII
Feb 27, 2014 08:43 PM
94svt50
Mar 30, 2013 09:27 PM
Scharfire
Aug 30, 2012 06:36 AM
ogden45
Nov 19, 2011 01:46 PM
