Chirping noise from dash
Old Apr 13, 2013 | 12:27 PM
symaxwell's Avatar
Originally Posted by Bob Loblaw
symmaxwell - I can't say for sure that my problem is fixed, but it has been gone for a couple days now. In my search for the noise, I removed the A-pillar trim and tightened down the plenum air intake (black cowling at the bottom of the windshield). Mine was cracked in the middle and one of the rubber grommets for a screw had backed itself out. I'm about to drive for a few hours today so I think I will know definitively by tonight whether it's fixed or not. I'll keep you posted.
My plenum air intake is also cracked. I'll check mine too.
Old Apr 14, 2013 | 11:32 AM
G150driver's Avatar
Loose and/or cracked exterior A-pillar trim can also create a faint screeching, chirping noise above 45 or 50. The same thing just happened to me about a month ago. It must be that time of year. Mine was on the driver side at least. So it was easier to diagnose- just reached out the window and grabbed it.
Old Apr 14, 2013 | 11:59 AM
jfall's Avatar
2001 Discovery.
Chirps only on hot days.
Feels as when the body flexes laterally the chirp come on loud.
Need to catch it on the cell phone and onto youtube.
Old Jun 26, 2013 | 11:38 AM
abelonline's Avatar
I promise this isn't like all the other blower motor threads out there!
Here's the sequence:
1) Heard chirping noise commonly diagnosed as bad blower motor. Noise typically stopped when fan turned off.
2) Removed, cleaned, re-installed blower motor.
3) Chirping came back, but ONLY chirps from ~40-65 mph. Did not stop when blower motor turned off.
4) Removed blower motor again.
5) Chirp is still there, only from ~40-65 mph (without the blower motor installed).
Since the chirp doesn't occur except for a certain speed range, I'm thinking that either the ram air pressure at that speed or some sort of vibrational resonance is rattling something in the dash. Is there something specific I should check before tearing apart the dash?
P.S. Drive shaft rebuilt last week. So don't even go there
I have same chirp, regardless of truck speed, but definitely dependent on fan speed...can you help walk me through blower motor cleaning?
Old Jun 26, 2013 | 11:42 AM
SuperSport's Avatar
Here you go:
https://landroverforums.com/forum/di...llation-55530/
Old Feb 20, 2017 | 12:32 AM
DailyDrivenTJ's Avatar
Seems like I am having the exact same problem OP had.
Any update on this?
Old Feb 20, 2017 | 12:40 PM
SuperSport's Avatar
Any update on this?
Please see the post just above yours.
Old Feb 20, 2017 | 01:19 PM
mln01's Avatar
OMG! (That's the first time I've ever typed that.). SuperSport is alive! Haven't seen you for a while. I recall you sold your Rover. Thanks for keeping your finger in the pot.
Old Feb 20, 2017 | 02:08 PM
SuperSport's Avatar
Thank you for noticing. Yeah, I don't have a lot to add since I don't have it anymore. I miss it a lot!
Old Feb 20, 2017 | 11:22 PM
Like I said I have the same problem as the OP. It has nothing to do with fan. I fixed that issue by oiling it last season. I know what that sounds like. It is very irregular chirp.
