Chirping Noise from underneath car
Old May 29, 2019 | 09:32 PM
dealbergaria11's Avatar
Default Chirping Noise from underneath car
I have heard a chirping noise for the past few months and it gets a little faster when I drive faster. I can only hear it when I'm driving slowly because when I speed up, the wind noise is too loud. My first though would be the front driveshaft but I just replaced that 6 months ago. Any ideas?
Old May 29, 2019 | 09:54 PM
ZGPhoto's Avatar
It's...your first thought.
Old May 29, 2019 | 09:55 PM
Even though it was replaced less than 5 thousand miles ago?
Old May 30, 2019 | 12:40 AM
Richard Gallant's Avatar
@dealbergaria11 yup even though, I went through the same denial. Is is easy to check if you have CDL, pull the front shaft lock your CDL and go for a drive. That what convinced me, it easy enough to get out 2 9/16 wrenches and maybe an hour tops.
I do not know the age of my original - it was greasable, and while I kept up on it I am pretty sure the OP did not. But the same issue and chirping clicking noise. When I got mine off it was pretty obvious the centering ball was binding, not a lot but enough. The rest was not taking grease well, so I replaced it and no more noises.
Old May 30, 2019 | 12:54 AM
Well I know I don't have CDL because I have an 02 Discovery. My car also vibrates a bit when slow down; I read somewhere that might also be a symptom of bad U joints/ driveshaft. Does that pretty much confirm it's a bad driveshaft?'
Old May 30, 2019 | 06:05 AM
shanechevelle's Avatar
I replaced my drive shaft with one from eBay. Two months later the U joint failed and I was an hour and a 1/2 from home. I did manage to get home with it but when I disassembled it all the pins, bearings, were gone on 1 of the joints and the cap was severely cracked.
Also, big truck, junky joint. I would replace that immediately.
Old May 30, 2019 | 12:51 PM
Is there a way I can confirm if its the driveshaft making the chirping and ticking sounds under the car?
Old May 30, 2019 | 12:57 PM
KernowDiscovery's Avatar
I think it was seven years ago that I posted this very same question on this very same forum. I have to laugh now at how freaked out I was and how it took another member to talk me off of the ledge after reading too many DiscoMike posts. I described the chirping and vibration/drag to him the very same way. It turned out being the driveshaft and u-joints which were shot, the yoke on the driveshaft worn down and the u-joints, being original, had no greasable zerks.
Although the noise you're hearing could potentially be due to something else, such as a faulty wheel bearing, as suggested, I'd start with looking at your drive shaft assembly again. When you state that the drive shaft was replaced six months ago, were the u-joints replaced? I was lucky - I had someone in town who helped me out, I ordered a replacement driveshaft off of ebay and locally sourced the u-joints and he rebuilt it. Knock on wood, that was seven years ago and I haven't heard the sound since.
Old May 30, 2019 | 01:52 PM
NewToTheTwo's Avatar
Would this be a reasonable test?
Put it on jack stands, put it in drive and crawl underneath.
**At your own risk** of course But thats what I'd do....
Old May 30, 2019 | 02:46 PM
Dave03S's Avatar
Sometimes it needs to be under load to make noise... Other times you can just grab it and twist and it will be immediately obvious. I recently had a noise that turned out to be the nuts on the front of the rear drive shaft had come a few turns loose. Could not replicate the noise while it was jacked up. Only way to tell was to put a wrench on it and check the torque. Have you checked the bolts on your new driveshaft?
