Chugging / Missing Problem on 98 Disco
Have a 98 Disco 1 with 75k miles. Normally runs great. A few months back after sitting for a week in an airport garage, it started sputtering, chugging and running like the Catalytic Convertor was completely jacked or the timing was way off.
Had it towed to a shop ( a seasoned rover mechanic) found to have codes for a bad camshaft and crankshaft sensors - both were replaced.
Problem disappeared, for a while.....
Back in shop again. No code errors, the poor running problem doesn't always happen - only sometimes (usually when my need for the truck is pressing)
My mechanic replaced the timing chain, and tested known good ECM, Air Flow Meter and Catalytic Convertor. Yet the problem remains, it seems to get worse (poor running, chugging, missing, it sounds and feels exhaust related) when placing load on engine or fast starts. Some days it runs just fine, on other days it is undriveable and can not accelerate over 25mph and sounds bloody aweful.
Any ideas? We've tested or replaced the following items:
ECM, Convertor, Air Flow Meter, Timing Chain, Crank Shaft Sensor, Camshaft Sensor.
Could this be water related? It seems to be worse when it rains. Which is kinda crazy.
Thanks - Peter
Thanks - Peter
RE: Chugging / Missing Problem on 98 Disco
I agree, When I got my 95 used a year ago same thing, changed the plugs that didn't help, changed the wires and that was all it was!!!!! Has been fine since. The dealer I bought it from knocked off $500 off the price for the running rough when I bought it.
Thanks for the response guys.
Here a little more info. My mechanic was working on it for a while - and ultimately didn't charge me for any labor, since he didn't figure it out. The problem is very intermitent, I drove it all weekend without any trouble and with the new timing chain it seems like a new truck.
Until this morning, it started - but didn't sound quite right. The exterior of the truck was very wet from the rain last night. I could not accererate beyond 10 MPH - and it chugged and sputtered like it was being strangled. I read on the forum that the MAF may be faulty and disconnected it and cleaned with MAF cleaner. I let it dry and reconnected, no difference. I let it sit for a bit, then on a whim I disconnected the electrical connections to the MAF and removed the AIR FILTER, then started the car. It sounded great. I reconnected MAF, replaced AIR Filter and it is back to running great - although with a little hesitation.
Given this - what the heck is going on? Is my MAF on the fritz? Did starting without the MAF connected rest the signal to the ECU? Ideas? Do you think there may be a water issue?
Also on the forum someone mentioned clearing the Sedimenter for the fuel line, do non- Disels have those?
Thanks again. Peter
I bought new wires and plugs as reccomended and will install tonight.
Thanks again. Peter
ORIGINAL: pedro_malo
T
Thanks again. Peter
T
Thanks again. Peter
No Sedimeter, but disco 1's have a fuel filter above the right rear wheel. A real booger to get off, but you should change it out.
I'll bet a pastrami on rye that it's the plug wires.
Dave
Thanks guys -
We should find out soon. It rained last night and is humid as all get out this AM. I'd love to owe ya a pastrami and rye. The bad wire and humidity diagnosis make sense, this New Mexico Disco - wasn't brought up to deal with HOTlanata weather. I threw on the best the local part store had in stock. Will order Magnecor brand.
P-
P-
on
Thanks again. Peter
Thanks again. Peter
Does you check engine light come on when you turn your keu to the 2nd. position?
Well - It looks like the new plug wires did NOT do the trick. Although- I drove the truck on a number of errands last night following the install of new plug and wires - it ran great. This morning (8AM) it was missing and chugging like mad. It was increadibly humid this morning - don't know if that is related. The check engine light did come on. Popped the hood checked all the wire connections, everything was connected correctly - left hood open. Just now (10AM) started and sounds fine, although check engine light is still on. It is significantly less humid right now.
Will take Mike's advice on the MAF, although a bunch of folks recommend cleaning.
I just don't get whats going on, runs fine sometime and is a bloddy chugging and gasping mess at others.
Ideas? Is there possibility of a humidity sensor issue? Since I live in Atlanta this could be a pretty big issue.
looking forward to a Pastrami on Rye.
