Cigar lighter is loose in my center console--how to fix?
Hey guys, my center console cigar lighter is no longer secured. It's still got power to it, and I use it daily for my V1 detector,....but the entire lighter assembly is loose and free to be pulled completely out of the console. Thinking it's probably just a failed plastic retainer clip and wondering if I have to remove the console, and replace the entire lighter assembly to fix this.
Brian in Cedar Park
Brian in Cedar Park
The lighter is held in by the green surround. It has a little tab on it. If that is broken then you will need a new lighter assembly. It could just be it is not pushed in. But regardless you need to pull the console to get to it. Not that difficult to do.
$24 on ebay for a used one.
Land Rover Discovery I II Cigarette Lighter Assembly | eBay
replace it with this... Dual USB Charger Socket - Blue Sea Systems
It supposed to fit right into the hole from the lighter.
Here is the Britparts version (looks like it's a re-branded Blue Sea)
Britpart
Britpart
Britpart
Britpart
Just seen this on ebay. Looks very close to what is in there now except blue in color.
12V 120W Car Motorcycle motorbike Cigarette Lighter Power Socket Plug Outlet 3 | eBay
Rover_Hokie
04-05-2014 11:09 AM
Phototone
04-16-2008 01:14 AM
Phototone
Audio/Visual Electronics
04-16-2008 01:11 AM
