CKPS keep engine from turning over?
Old Mar 29, 2015 | 06:00 PM
  #21
jafir's Avatar
Incorrect 4th gear ratio = bad maf.
Old May 29, 2015 | 11:32 AM
  #22
cybercop's Avatar
Well, after almost 2 months of working perfect, it has done it again😡
Old May 29, 2015 | 11:37 AM
  #23
dgi 07's Avatar
Was it hot? (Engine and ambient temperature )
Old May 29, 2015 | 11:46 AM
  #24
cybercop's Avatar
Well, once again I drop everything to head my daughters way and when I'm about 10 minutes away, it starts.
She said all she did was move the steering wheel around.
The ignition doesn't go thru the Rotary coupler in the steering column, does it?
Old May 29, 2015 | 12:04 PM
  #25
cybercop's Avatar
I don't "think" so! Happened once again after eating, so truck was sitting for at least 30 min. It's only 82 degrees outside. She said temp gauge wasn't over 1/2. I have prepped her to pay attention to the temp.
I guess she needs to stop eating and stay within 10 minutes of me!
Old May 29, 2015 | 03:17 PM
  #26
cybercop's Avatar
Are there specifically any grounds to check. I checked the big 3, can't find anything loose.
Old May 29, 2015 | 11:37 PM
  #27
disc oh no's Avatar
I have seen this happen with bad connections at the ignition switch. You may want to check out the connectors and the wires on the switch. If there's high resistance, they will start to burn.
I wouldn't replace the crank sensor, it has nothing to do with your problem. All it does is send an input to the computer. If it was bad, it wouldn't run, but it would certainly turn over.
Old May 30, 2015 | 03:16 AM
  #28
cybercop's Avatar
Yeah, I'm leaning towards the ignition switch as well! Thanks for a confirmation in that direction
Old May 30, 2015 | 06:08 AM
  #29
dgi 07's Avatar
I love that everyone keeps saying this..... but whatever. Ignition switch, is possible. That reaches the end of my experience though. Our ignition switches are all electronic (monumental pain when they fail)
Good luck OP.
Old May 30, 2015 | 01:02 PM
  #30
OffroadFrance's Avatar
Possibly the ignition switch or it's circuit or the 12V low amp starter exciter wire spade connection to the starter solenoid.
