Classic U joint noise?
Old Apr 21, 2016 | 01:39 PM
DiscoBuckeye's Avatar
Default Classic U joint noise?
Quick question.
When I'm going about 30mph give or take 5 or even 10 mph,flat ground, and I tap the gas I get a clank and then again when I lift. Sounds like it is coming from the rear. What can I do to try and duplicate it with the wheels in the air or on the ground?
Tanks
Old Apr 21, 2016 | 05:38 PM
Alex_M's Avatar
First think I would do would he to drop the shaft and check for problems with it out of the truck.
After that, either have the u-joints and centering ball replaced or check the diffs. Also make sure the diffs and transfer case have enough oil in them.
Old Apr 21, 2016 | 06:58 PM
Extinct's Avatar
Classic u-joint noise - does it do it when you shift from reverse to forward or vice versa?
Old Apr 21, 2016 | 07:19 PM
No, but the sound is similar
Old Apr 22, 2016 | 06:15 AM
Extinct's Avatar
If the front shafts has not been done I would suspect it first.
Old Apr 22, 2016 | 06:41 AM
I would have thought that as well but the sound is pretty clearly from the rear
Old Apr 23, 2016 | 05:32 PM
Extinct's Avatar
The one other thing you might want to check (beside the driveshafts u-joints would be the retaining nut on the center shaft in the transfer case and the retaining nut on the rear axle yoke (assuming you are sure it is from the rear).
I recently had a Rover with a bad transfer case - the nut backed off the center shaft in the transfer case, the gear pitch drove the shaft our, and the result was ground up gears. Owner had had the truck 5 years and never had any work done to the transfer case. My guess is someone at the factor just did not peen the nut correctly and over the years it finally worked loose.
Loose yoke nut on the rear axle could allow the bearing preload to come loose, allowing slack between ring and pinion - have seen that once but would not expect it.
Good luck!
Old Apr 24, 2016 | 06:58 PM
Good luck!
Yikes you went way over my head.
I did change the dif oil and TC oil this weekend. All three were full up and looked pretty good. Clank is still there
Old Apr 24, 2016 | 08:08 PM
cappedup's Avatar
To me it sounds like you have the classic on/off throttle diff clank.
I've got it, but then I also don't. I can drive so it clanks and I can drive so it doesn't clank. My missus hasn't mastered driving without the clank, grr.
Try feathering the throttle very gently as you brake and accelerate. Does it go away?
It's been written up as diff wear, either front or rear.
As mine has gone away (I drive it so it doesn't clank) ive stopped worrying.
Sound familiar? Or am I way off?
Old Apr 24, 2016 | 08:10 PM
spot on BroChacho
