Cleaned MAF, Throttle Body and IACV Valve. Now my motor dies after start up. WTH?
Old May 9, 2016 | 04:20 PM
Rovernewb15's Avatar
7th Gear
Default Cleaned MAF, Throttle Body and IACV Valve. Now my motor dies after start up. WTH?
Engine starts, then immediately dies. Was running perfect before, but was doing some routine maintenance. The IACV valve was filthy, so I suspect that is what I messed up. I used MAF cleaner for the MAF, but regular Throttle body cleaner for the rest. Did the throttle body cleaner do something to the IACV valve or is there something else I'm missing here? Thanks! BTW, I have an '04 Disco II, 4.6L
Old May 9, 2016 | 05:01 PM
disc oh no's Avatar
Try turning the key to the on position and see if the IAC vibrates. If not, it's probably dead. I'm not saying that is your problem, just something to check.
Old May 9, 2016 | 06:51 PM
Best4x4's Avatar
Sounds to me more like the MAF is unplugged or a hose on the IAC is loose.
Old May 9, 2016 | 07:59 PM
7th Gear
Well, it's the MAF. I unplugged it and the motor started right up. Guess I did something to it when I was cleaning it
Old May 10, 2016 | 12:53 PM
cappedup's Avatar
I've heard a few people have problems after cleaning the Maf.
Old May 10, 2016 | 04:51 PM
OffroadFrance's Avatar
I killed my MAF by cleaning it and I've seen a few MAF's killed the same way. MAF's AFAIK are not designed to be cleaned even if they do sell stuff for cleaning them. LR don't recommend cleaning a MAF.
Old May 10, 2016 | 09:46 PM
disc oh no's Avatar
Man! That's weird. I clean them in all my vehicles at least once a year and I have never had a problem. And I use brake parts cleaner.
Old May 11, 2016 | 11:27 AM
Shiftonthefly1's Avatar
Yep. Never clean them. You can see a lot of threads when guys do the same thing. Even with MAF cleaner. Lesson learned I guess.
Old May 11, 2016 | 11:51 AM
7th Gear
Mine was already on the fritz, I just pushed it over the edge. Found a new one for $30 online. It's not a Bosch, but I'll see how it works
Old May 11, 2016 | 02:21 PM
DiscoBuckeye's Avatar
I cleaned mine with no noticeable change
