Cleaning Parts & Reassembly Advice
Old Mar 24, 2016 | 12:06 AM
chubbs878's Avatar
Default Cleaning Parts & Reassembly Advice
I searched for an old thread on a transfer-case rebuild but I haven't come across it. I want to clean the inside of an old front output housing, along with the diff/hi-low gear shaft. I was thinking about sticking it in a parts washer but wouldn't the solvent strip the lubrication off everything, resulting in the need for assembly lube on shafts and moving parts? I don't know anything about it whatsoever but I can see dirt/dust particles and there is a dark, greasy coating that should be removed from the larger surface inside the housing. I'm not stripping these parts down anymore than what is shown in pictures, unless absolutely necessary. I don't see signs of major wear so a rebuild isn't needed.
Old Mar 24, 2016 | 12:08 AM
chubbs878's Avatar
Gear set
Old Mar 24, 2016 | 12:10 AM
chubbs878's Avatar
Housing
Old Mar 24, 2016 | 12:13 AM
chubbs878's Avatar
Old grease
Old Mar 24, 2016 | 12:15 AM
chubbs878's Avatar
Everything I need to clean
Old Mar 24, 2016 | 12:19 AM
chubbs878's Avatar
Close up of particles
dusty1
Dec 7, 2014 01:57 PM
drcoop
Apr 16, 2014 06:43 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
momentum59
Jul 20, 2010 07:40 AM
meltdowndave
Dec 21, 2009 06:42 PM
