Cleaning Power Steering Reservoir?
I'm servicing my PAS pump and hoses, which means I'll also be flushing/putting all new fluid in the system. I've removed and drained my reservoir. There's some dirt sludge on the bottom and the filters have done their job as well—not clogged, but yes, dirty. Now, I've spent enough money on other repairs and have more yet that I expect to do. I'm not interested in replacing the otherwise good reservoir.
My question is: what cleaners if any are safe to spray into the reservoir to flush out the debris? Obviously, I'd need to make sure there is nothing residual when it comes time to refill the system, but I don't see a problem there.
Clamp the lines and remove the reservoir completely. Then use a can of brake clean and clean. Dry with compressed air, or air dry. Either will work. Then reinstall, refill and bleed. I tend to jack up the front and turn the wheel lock to lock to get the air out of the system. Then start and repeat. THEN take it off the Jacks and drive.
The following 2 users liked this post by dgi 07:
joshjellel (02-11-2015),
JUKE179r (12-21-2016)
Clamping through lines to prevent the fluid from dripping out? Do you guys not believe in working cleanly? We are talking about removing the power steering reservoir and cleaning the interior of it.
bcolins
03-30-2014 09:02 PM
Tim08
03-10-2012 10:05 PM
Barry Childs
11-20-2007 11:26 AM
