Cleaning Power Steering Reservoir?
Old Feb 11, 2015 | 05:14 PM
joshjellel's Avatar
Question Cleaning Power Steering Reservoir?
I'm servicing my PAS pump and hoses, which means I'll also be flushing/putting all new fluid in the system. I've removed and drained my reservoir. There's some dirt sludge on the bottom and the filters have done their job as well—not clogged, but yes, dirty. Now, I've spent enough money on other repairs and have more yet that I expect to do. I'm not interested in replacing the otherwise good reservoir.
My question is: what cleaners if any are safe to spray into the reservoir to flush out the debris? Obviously, I'd need to make sure there is nothing residual when it comes time to refill the system, but I don't see a problem there.
Old Feb 11, 2015 | 05:31 PM
dgi 07's Avatar
Clamp the lines and remove the reservoir completely. Then use a can of brake clean and clean. Dry with compressed air, or air dry. Either will work. Then reinstall, refill and bleed. I tend to jack up the front and turn the wheel lock to lock to get the air out of the system. Then start and repeat. THEN take it off the Jacks and drive.
Old Feb 11, 2015 | 05:54 PM
joshjellel's Avatar
That's what I was thinking for cleaning, especially since the straw will help blast the crud up close and personal, but I didn't want to find out the hard way that whatever I used was somehow corrosive to the polyester (or whatever) filter screen.
Thanks for the extra tips, too.
Old Feb 11, 2015 | 06:06 PM
mln01's Avatar
If you're removing it and will be able to let it dry thoroughly off the truck why not just soap and water?
Old Feb 11, 2015 | 06:16 PM
dgi 07's Avatar
Brake cleaner won't leave residue. Soap*... may.
Old Feb 11, 2015 | 06:46 PM
cybercop's Avatar
Are you talking about cleaning the insides of the pump or just cleaning the crude off it?
If cleaning the inside. I don't understand how clamping the hoses will help.
Old Feb 11, 2015 | 07:37 PM
dgi 07's Avatar
Clamping through lines to prevent the fluid from dripping out? Do you guys not believe in working cleanly? We are talking about removing the power steering reservoir and cleaning the interior of it.
Old Feb 11, 2015 | 08:07 PM
joshjellel's Avatar
I believe in working cleanly. Freakin' Bounty must love me!
For this, I slowly and carefully removed and drained the lines (and reservoir) into a small container vs. clamping. Less fluid to bleed later.
Old Nov 9, 2025 | 07:00 PM
Tranceatlantic's Avatar
Thanks
I’ll see if i get the bottle out and spray some brake cleaner through it
Old Nov 9, 2025 | 09:56 PM
Harvlr's Avatar
10 year old thread. Don't use any cleaner unless you can ensure there's none left when you're done.
Tim08
Mar 10, 2012 10:05 PM
Classklown90
May 3, 2010 08:47 AM
Barry Childs
Nov 20, 2007 04:41 PM
Barry Childs
Nov 20, 2007 11:26 AM
