click click click stop???
Old Jul 27, 2009 | 10:40 AM
hilltoppersx's Avatar
yeah i'm getting 3 spicer u joints and the spicer centering ball kit. i checked out all the parts before he started doing the work. Are the rear shafts as likely to fail as the fronts? should I look at doing the rear next? Thanks Mike.
Old Jul 27, 2009 | 10:52 AM
Torancis_LR's Avatar
The rear shaft is fine. Just make sure you keep an eye out for the roto-flex coupling. When it cracks and vibrates, you'll need to replace it.
Old Jul 27, 2009 | 11:25 AM
How often do you grease your grease fittings? Should be at least twice a year, if not go replace the rear u-joint also and watch for cracks between the 6 bolts on the rotoflex.
Also remove the plugs on both shafts, insert a grease fitting and lube both slip shafts also, then replace the plugs.
Old Jul 28, 2009 | 04:36 PM
rebuilt front drive shaft reinstalled. clicking and squaking gone. thank you all!!!
CapeRover
May 3, 2013 04:35 PM
toad2
Jul 31, 2010 07:17 PM
hsmatharu
Defender
Aug 23, 2006 12:33 AM
614buxnut
May 18, 2006 03:24 PM
