Clicking noise under the dash
Old Feb 18, 2014 | 07:05 PM
cbwhitley's Avatar
Default Clicking noise under the dash
Hello all
Got a question about a strange clicking noise under the dash when my 2004 discovery is started. When I start it it clicks about 5 to 10 seconds and stops. What can this be???
Old Feb 19, 2014 | 04:56 AM
00&04 Disco's Avatar
Where is the sound coming from? Left, right, under steering column?
Old Feb 21, 2014 | 04:37 PM
cbwhitley's Avatar
Sounds to me like it is coming from under the steering column. Sounds like some sort of vacuum leak that has to build up pressure ..pop a..pop a..pop a..pop a...than then quits
Old Feb 21, 2014 | 05:18 PM
SuperSport's Avatar
Without hearing it, total guess, but how about blend doors? Kinda sticking?
Old Feb 21, 2014 | 06:33 PM
zski128's Avatar
Theres that little temp sensor fan behind the little slats to the left of the steering column. It was all clogged up on my 2004 when we first got it and caused a clicking noise.
Old Feb 21, 2014 | 07:52 PM
jfall's Avatar
I bet I know.
The brake pedal switch is going bad.
The brake pedal switch is a compound switch that operates the solenoid that keeps your gear shift locked in Park until the brake is pressed.
If you are lightly resting your foot on the brake pedal that could do it.
Or
the switch is going bad.
The noise is really from the console area? correct? A clicking..
Old Feb 23, 2014 | 07:53 PM
cbwhitley's Avatar
I think the blend doors might be it. There was a time this winter when the engine was warm and was still blowing cold air. I cranked the temp control to low and then moved it up to high and the heat worked again. How is this fixed .
Old Feb 23, 2014 | 10:29 PM
SuperSport's Avatar
I haven't dealt with them on the land rover yet, but on other vehicles, it's a matter of finding all the pivot points and lubing them, and make sure the vacuum lines are not broken and are connected everywhere. There is also the main switching valve for the vacuum lines. Make sure it's working. It's a lot of tearing apart and searching...
rezzrover
May 7, 2013 06:02 PM
kpl1228
Feb 5, 2012 02:47 PM
davidlafrance
Dec 3, 2011 10:40 AM
