clicking noise whn in neutral, coming from under "engine area"
Old Feb 5, 2012 | 10:33 AM
kpl1228's Avatar
Default clicking noise except when in neutral, coming from under "engine area"
If I idle, I hear it: if I'm in drive, I REALLY hear it: speeds up as I accelerate. But the engine sounds great when in neutral. Thought it was engine, could be tranny or differential etc etc etc............got under the truck and have NO idea where it's at. Sounds like lifter noise, but again, at neutral, clicking goes away (while driving if I shift from D to N it takes about 2-3 seconds as the clicking gradually fades away to nothing). Truck runs and shifts great otherwise.
Old Feb 5, 2012 | 11:15 AM
There is a plate that bonds the tranny to the flywheel, called the flex plate. If cracks begin it can be a source of the "TICK". In "N" there is less load from the transmission.... suggest your search forum for "cracked flex plate", there have posts with photos. See attached.
File Type: pdf
Old Feb 5, 2012 | 02:47 PM
As can the cam bearings and the oil pump, all can make a ticking sound under the truck.
cbwhitley
Feb 23, 2014 10:29 PM
rezzrover
May 7, 2013 06:02 PM
apinky96
Mar 11, 2011 09:09 AM
kpl1228
Jan 18, 2010 04:30 PM
