Clicking Relay 3 (interior)/interior lights flashing until car warms up
Old Mar 3, 2019 | 02:59 PM
Armando's Avatar
Default Clicking Relay 3 (interior)/interior lights flashing until car warms up
Hi Everyone,
I've had my Disco 2 since September 2017 and am very happy with it. Unfortunately, it's started doing something very annoying the last few months.
When I start it in the morning, Relay 3 (rear window) will click incessantly and the interior lights will flash until it warms up. It appears to be pretty widespread as the brake switch won't trigger the transmission solenoid unless I catch it between clicks.
After it warms up, these problems go away. Has anyone else had this problem? Removing the F13 interior fuse stops the clicking relay, but the lights will still flash.
I don't even know where to start looking for the problem. Any pointers would be appreciated.
Old Mar 3, 2019 | 04:03 PM
Best4x4's Avatar
Make absolutely sure your battery terminals are extremely clean and tight. Sounds like low voltage at startup to me or an issue with the fuse box under the dash.
Old Mar 3, 2019 | 04:16 PM
Armando's Avatar
Thanks! That sounds like solid advice.
I'll start logging my voltage while clicking vs while not clicking. I have a bluetooth fm connector that plugs into the cigarette lighter. Is there any reason I shouldn't use that reading for my tracking?
With regards to the battery: the terminals used to be an issue but they are now very tight.
With regards to the fuse box: My local junkyard sells them pretty cheap and they get Disco 2 regularly. Should I just swap it out for a new "old" one?
Old Mar 3, 2019 | 06:39 PM
Ben Matheson's Avatar
Try locking and unlocking the doors a couple times before starting it. Lube all the actuators. Sounds like one doesn't think it's fully latched?
Maybe give all the doors a firm open and close
Cheap and easy to see if that changes the symptoms any
Old Mar 3, 2019 | 07:20 PM
Armando's Avatar
Hi Ben,
Thanks for the idea. My power lock doesn't work on the driver's door. I wasn't in a hurry to fix it but will now move it to the front of the list.
I'm not too hopeful that will do it though. The clicking usually goes away after the car warms up. If I drive it 30 minutes to work, it'll usually go away by the time I get to work. Also, it won't click even after I let it sit for 4 hours and then go out to lunch.
I'd say it needs to sit for about 12 hours for the clicking to start.
Old Feb 28, 2020 | 05:37 PM
Armando's Avatar
I have an update. The clicking was fixed by changing the fusebox. There's a young man named Joe who runs the South Florida Land Rover Club. He diagnosed it right away and fixed it for me. He's a nice guy and very knowledgeable.
Old Feb 29, 2020 | 10:35 AM
redwhitekat's Avatar
can you expand more on the fix. Like what was it ? A relay wire ? Fuse ?
Old Feb 29, 2020 | 10:44 AM
Armando's Avatar
i previously changed the relays and it did not fix the problem. It went away away after we replaced the entire interior fusebox. Please note not all interior fuseboxes are compatible. The 03-04 will not work for previous years.
bosshogt
Jan 10, 2012 05:25 PM
ebg18t
Dec 18, 2011 05:06 PM
JKFL03
Nov 27, 2011 12:21 PM
qdriskell
Sep 15, 2011 06:04 PM
drpenaranda
Jul 27, 2006 09:08 PM
