Climate Control bulb replacement
Old Jan 12, 2011 | 04:58 AM
edvan94's Avatar
5th Gear
Default Climate Control bulb replacement
The light for my climate control temp switch is out.
I removed the switch cover to reveal a small light bulb.
It looks like it twists out or is it a peanut bulb (bayonet-type)?
Also can anyone explain how the climate control unit is removed from the center console?
Lastly, I have read the replacement bulbs are only available through the dealer. Anyone find another source???
Thanks,
Ed
Old Jan 12, 2011 | 05:25 AM
Fireman's Avatar
The bulbs need to be replaced from the inside of the unit, so the unit needs to be removed from the dash. Remove the coin tray/ash tray holder. Remove the clock and switches (use a credit card along the top and pop them out). The is a metal clip on the left and right side of the unit; depress the clips and slide the unit out and unplug. You with then need a very small phillips screw-driver to open the unit.
BTW, the bulbs are available through BP Utah or Rover's North. Hope this helps...
Old Jan 12, 2011 | 05:46 AM
Mark_Bedell's Avatar
6th Gear
Default Security video course, Online training videos, Wireless Integration by Shon Harris
This topic is new for me thanks guys
Green Blood
Dec 22, 2018 04:40 PM
Classklown90
Aug 21, 2010 07:24 PM
SantaCruzRoverGirl
Jan 20, 2009 02:49 PM
jasonsLR
Sep 3, 2005 02:39 PM
dbs600
Jul 11, 2005 08:44 PM
