Climate control swith from dual zone to single control?
Old Jan 21, 2013 | 10:57 PM
Green Blood's Avatar
4th Gear
Default Climate control swith from dual zone to single control?
Maybe I'm crazy but I seem to recall that I could change the driver-side temperature setting on the climate control in my DII and it would change both sides at once, unless the passenger side was subsequently changed to a different temp. And then there was a way to 're-set' it so that the driver side change would control both sides.
I have not been driving it much in the last few months and now each side is independent and I have not been able to find a way to change it.
Am I imagining things? Maybe this was one of my other cars but I thought for sure it was like this in the Disco. But couldn't find anything in the manual.
Any insight or clarity on this would be appreciated. And I can quite wondering.
Cheers,
Old Jan 22, 2013 | 06:40 PM
Rover Curious's Avatar
I hope I'm wrong, but I don't think the Disco offers this option. My boss's truck (Dodge) has dual zone climate control, and it has a "Sync" button that will sync both sides together. I hope someone else chimes in and tells us there is a way to do this, cuz I'd like to get mine to do that as well.
Old Jan 22, 2013 | 06:47 PM
Big Jim Swade's Avatar
I haven't found where you could do that.
Old Jan 22, 2013 | 07:51 PM
GURU06's Avatar
The only thing Land Rover offers is the "auto" function to maintain a set / chosen temperature for each side, or both sides if they are set to the same temp.
When you first activate the auto button is turns the economy off so one needs to watch that unless you want the A/C running.
Other than that, I don't know of any way to control both sides with just one control.
Old Jan 22, 2013 | 10:07 PM
4th Gear
Guys,
Thanks for the feedback. For some reason this was stuck in my mind but I must have been confusing this with another car I've owned.
Cheers!
Old Dec 22, 2018 | 04:40 PM
Anthony Frantzis's Avatar
There is no option that exist on the disco
Drake Anderson
Feb 12, 2019 08:14 PM
Anthony Frantzis
Dec 22, 2018 04:18 PM
pkppunk
Oct 5, 2013 04:00 PM
showbet
Sights N Sounds
Mar 7, 2009 07:36 PM
