Climate Control Issues! Help!
Old Oct 19, 2008 | 03:50 PM
Desertdualsport's Avatar
7th Gear
Default Climate Control Issues! Help!
Hi All,
I have a 2003 Disco that is the wife's daily driver. About 2 weeks ago, I noticed the climate control blowing on high all the time. after a function check, here are the results;
1. Fan is on high all the time while in auto, regardless of what the climate control is "trying" to do.
2. If I manually adjust fan speed, it stays on high, but shows the selected speed on the display.
3. Temperature blowing from the passenger side is approx 5 degfrees warmer than drivers side.
Is this a trashed climate control unit?
thanks in advance!
Nick
Old Oct 19, 2008 | 05:14 PM
Default RE: Climate Control Issues! Help!
When you turn it off what happens? Nothing, it just shuts off? How about ECNO mode, then what?
Old Oct 19, 2008 | 05:42 PM
You may have burned out the resistor pack that helps change the blower motor fan speeds.
Old Oct 20, 2008 | 06:53 PM
7th Gear
I like the idea of the resistors. Isd it a step up/down set up? Have a wiring diagram handy?!
If you turn it off, is turns off like normal, and in econ mode, it just shuts off the AC compressor like it should
Nick
Green Blood
Dec 22, 2018 04:40 PM
sstevensonm
Jun 22, 2014 03:23 PM
cardinal77
Jan 18, 2012 02:39 AM
Rioja Red
Nov 5, 2007 06:08 PM
Surfrider1468
Sep 21, 2007 04:00 PM
