Clock Light
yes there is a bulb. you can get it at the dealer for like $3. all you do is use two thick business cards, not credit cards they are too thick. Slide one above and one below the clock and the door lock switch (they are one unit). There are tabs in there you wont really feel them but once you catch the tabs on top and the tabs on the bottom the clock will kind of come loose and slide right out. once its out just disconnect the harnesses for the door locks and the clock and you can flip the clock over and see the bulb in there. this is common.
For replacing not only the clock but also for some of the bulbs for the climate control systems, I usedNeowedge
Item# Incandescent , Color: Clear , Lens: Type C (T5)$1.99 USD From autolumination.com
The only thing now is to figure out how to replace the bulb behind the door lock rocker switch...
FW
FW
FW
FW
http://www.discovery2.co.uk/sunroof_switch.html
