Clock removal on Disco2
Old Oct 5, 2013 | 12:15 PM
  #21
jalodge's Avatar
Originally Posted by Street Wolf
Put an LED in it and forget about it.
What size and color LED is that?
Old Oct 22, 2013 | 08:22 PM
  #22
jalodge's Avatar
Has anyone else done the LED conversion?
Old Oct 24, 2013 | 08:12 AM
  #23
jfall's Avatar
Radio shack
Lamp assemblies, Miniature bulbs & lamps, Hobby & Do-It-Yourself | RadioShack
I would strive to put an LED in there.
To put in an LED - you may need to put a resistor in series.
The LED will have a max current rating of so many ma's milliamps and this rating must be respected.
E=I*R
R = E/I
If E is 13.8 volts and I is .022 (for 22 ma)
R = 13.8 / .022
630 OHM resistor
Color code on resistors is
B B R O Y G B V G
1 2 3 4 5 6 7 8 9
Green Violet Brown I think..
Ah well here is a guide
http://www.google.com/url?sa=t&rct=j...55123115,d.cGE
Old Oct 24, 2013 | 05:22 PM
  #24
jfall's Avatar
I can't get the clock out.
Where to put the two thin credit cards under?
And how far back?
I have green LEDs and a resistor and am ready to install
An LED
Old Oct 24, 2013 | 06:48 PM
  #25
jalodge's Avatar
You push the cards above the clock/central lock assembly. They go pretty far back and it takes some wiggling around. It will eventually start to slide out and you can pull in out from there.
Old Oct 24, 2013 | 10:11 PM
  #26
acg's Avatar
acg
Old Nov 5, 2013 | 07:16 PM
  #27
jalodge's Avatar
An LED
Did you ever do this?
Old Nov 5, 2013 | 11:25 PM
  #28
jfall's Avatar
YES I did get that clock out.
Many many thanks.
I just put in a little 1.2w Orsam bulb.
I did not make the LED bulb with the resistor.
The clock - is a bear to get out.
You need two credit cards but a bit thinner and you need to wedge them in
bending the clock frame a bit and the dash plastic.
And you need to convince the clock to slide out with a thin screwdriver.
The lamp is not soldered in. Just a typical dash lamp which is put in by turning it counter clockwise 1/2 a turn and the lamp pops out.
Once done the clock pops back in easy.
Old Nov 6, 2013 | 04:25 PM
  #29
jalodge's Avatar
I was going to try the LED in hopes of not having to replace it again but I don't want to go through the trouble of making a circuit with a resistor. Did Street Wolf use a resistor in his?
aguison
Sep 17, 2012 11:40 AM
JimmyG
Dec 18, 2011 01:19 PM
tom_meeks@yahoo.com
May 24, 2008 11:04 AM
JA-NH
Nov 23, 2004 01:40 AM
JA-NH
Nov 23, 2004 01:38 AM
