Clunking/clicking drive train sound
Guys - any help appreciated.... I searched here and other forums for this situation but nothing I could find on this exact situation.
Truck: 2004 D2 SE
91,xxx miles
Recent work: Brand new front prop shaft. New Drag link, main ball joints, new track rod and steering dampener.
Issue: Clicking or clunking noise when letting off the gas. Appears to be coming from the front left but not sure. The clunking happens only when Im going straight and not on the gas. I do not hear the clunking when I am on the accelerator, nor when on the brakes. Additionally, I do not hear it when I turn to either left or right. Only straight and not on the gas.
At first I thought it was going to be the faulty prop-shaft issue I have read about so much. When I replaced with a brand new unit today, the sound persists.
My next guesses are: 1) Faulty Universal/CV on the axle(s) (but I dont hear the issue when turning right or left) or 2) a warped rotor knocking the brake pads around?
Any other ideas friends?
Thank you!
Truck: 2004 D2 SE
91,xxx miles
Thank you!
I wouldn't call it slop so much, its a click/clunk that is based on the speed I am traveling. The faster I go, the faster the tick happens. So, something is definitely hitting something as it rotates. My main concern is, its getting louder as time goes by so I think its something I should be concerned with.
Josh: Good advice. I just went out and changed completely that fluid in the front Diff. The old fluid was a little low and really black but sadly, the refill with new oil didn't solve the issue. I only drove it about 1/2 mile though...does it take a while for the new oil to seep in to places? I cant imagine it would take a while... so I guess Im open to other thoughts still.
Thanks Josh!
Thanks Josh!
Thanks Josh!
Best of luck
DiscoJon
07-14-2019 01:51 PM
