Code 1170 and O2 sensors
Old Nov 5, 2019 | 10:14 AM
Richard Gallant's Avatar
Default Code 1170 and O2 sensors
Off an on a offroading trip and this little pin head code showed up. it appears from monitoring the sensors to be related to an intermittent connection issue. When graphing the sensors one would occasionally not report.
Considering my Y pipe was dropped for a rear main seal change,and I had no issues prior, I suspect a the connector is not quite seated.
As I have to disconnect and re-seat them,are there any maintenance /clean up things that should be done to them
Old Nov 5, 2019 | 10:51 AM
Sixpack577's Avatar
A small amount of anti-seize on the threads if you remove them.
I would not clean the actual sensor tips with anything either.
Old Nov 5, 2019 | 11:10 AM
Thanks @Sixpack577 , I was not clear it was the connectors rather than the sensors I am looking at cleaning up and maintaining,
Old Nov 5, 2019 | 11:21 AM
Sixpack577's Avatar
Oh, sorry.
Then I would use electrical spray cleaner and dielectric grease on the plug pins.
jrf07d
Dec 13, 2017 10:35 AM
cobbcj7
Aug 18, 2016 01:07 PM
philwarner
Jun 17, 2015 10:27 AM
me 2
Nov 11, 2012 12:32 PM
jallert
Jan 22, 2010 10:29 AM
