Air box lid 03 vs 99-02 willing to swap lids
Old Nov 3, 2019 | 11:53 AM
Ben Matheson's Avatar
Default Air box lid 03 vs 99-02 willing to swap lids
Long story but went to replace my lid on the 04 with one I purchased with good clips but didn't fit. Is the 03 04 the one with the the larger or smaller opening?
Old Nov 3, 2019 | 12:06 PM
Best4x4's Avatar
03-04 = Larger
I personally run 99-02 intake hoses, MAF bodies on all my 04's. Slightly stronger and don't break as easy vs the 03-04 setup.
People will argue you MUST use the 03-04 setup with the 4.6L, but all that air going thru maybe a 1/4 inch wider intake tube/maf housing still goes thru the same exact sized throttle body as the 4.0L.... So the larger intake tube/maf housing do absolutely nothing.
Old Nov 3, 2019 | 12:14 PM
Since I have a good 04 lid.. I guess I could just swap the maf housing?
Anyone have a bad 04 MAF that would be willing to part with it?
Old Nov 3, 2019 | 12:55 PM
Best4x4's Avatar
You'd also need the smaller intake tube itself. It's a 3 part deal Air Box Lid, MAF, and Intake tube.
Old Nov 3, 2019 | 02:04 PM
So if the intake side of the MAF is a different size how is the Bosch maf part number valid 99-04…?
Old Nov 3, 2019 | 04:07 PM
Best4x4's Avatar
Sensor itself is identical. Housings are different diameters.
Old Nov 5, 2019 | 12:52 PM
mr. choodles's Avatar
I have an almost brand new 02 setup if you want. Been thinking of putting it up on sale:
1. Lid
2. MAF housing (modified with the screws so that you can take the sensor out)
3. MAF-to-throttle body tube
Long story short: Wanted to convert my '04 setup to '02. Bought all brand new parts but my fuel trims did not like it. Went back to the '04 setup. I also have the MAF sensor, but not sure if it functions well. Can be yours. PM me.
RoverSeriesInf
Dec 25, 2017 01:07 PM
KingKoopa
Jan 23, 2017 06:58 AM
matt3502
Nov 17, 2016 02:33 PM
dusty1
Mar 11, 2015 02:48 PM
Rover De Land
Aug 26, 2012 04:46 PM
