A code a day, is the Discos way!
Old May 13, 2010 | 01:10 AM
skatelove303's Avatar
Default A code a day, is the Discos way!
So today i got this code.
PO125.
Heat dont work and its gotta be related to this code correct?
Also does anyone know how bad it is to replace window wipers... Ha Pricewise and timewise.
So i stupidly turned on the wipers and snow was on the windshield and it stopped half way, i pushed them down, Which broke them lose... Now they dont work... Do i need a motor? i was thinking of just buying this.
http://www.roverparts.com/Parts/DKD100630G.cfm
Would that cover whatever i broke?!
Old May 13, 2010 | 07:59 AM
XCELLER8's Avatar
P0125...."insufficient coolant temp for closed loop fuel control"
based on what you have said here ......you are low on coolant.....top it up and bleed the system if neccessarry......and then find the leak.
wipers....is the wiper motor running ? if so they may just be loose on the posts
Old May 13, 2010 | 11:21 AM
First go check your coolant system for leaks and level. Do you know how to bleed the system. Do not drive the truck till you fix this problem cause if you are leaking you will over heat the engine.
As for the wipers, that was a dumb, possibly pricey guff. You will need to pull it apart and see if you broke the pivot points arms or motor.
Old May 13, 2010 | 09:50 PM
Sounds like it would be best to take it to Jeff or Over to MIT for the wipers. I think my thermostat is stuck open... Could that be it? coolant is fine for sure, I dont have any leaks because i just fixed a coolant problem.
yoshibond
Jun 13, 2012 05:35 PM
seniordon
Jan 17, 2011 12:26 PM
drdabbles
Aug 17, 2010 07:37 PM
Disco Fuego
Sep 29, 2009 02:39 PM
gsxrgessler
Jan 26, 2008 08:34 PM
