Code help
Old Jun 1, 2007 | 11:45 AM
rarick123's Avatar
4th Gear
Default Code help
I'm getting the following codes on my '03 Disco II, 70k miles...
Stored:
P0150 - O2 Circuit (Bank 2, Sensor 1)
P0174 - System Too Lean (Bank 2)
P1174 - Lambda control adaptation fault bank 2. Last occurrence - maximum signal
P0159 - O2 Circuit Slow Response (Bank 2, Sensor 2)
Pending:
P0441 - Evaporative Emission System Incorrect Purge Flow
I'm guessing from what I've seen that at least one (if not all four) O2 sensors are ready to be replaced, but the P1174 and P0441 are what I'm not sure about.
Old Jun 1, 2007 | 04:57 PM
Default RE: Code help
4 2's and then clear the codes, you will probably get the 0441 back, may have a bad purge valve.
Mike
Old May 5, 2008 | 12:54 PM
hriant88's Avatar
RaRick123 - did you get your codes problem resolved? if so, what did you do? Thanks!
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
