Code P0130 - o2 voltage dropping to zero, rotten egg smell.
Old Oct 3, 2024 | 03:30 PM
Jefe's Avatar
Default Code P0130 - o2 voltage dropping to zero, rotten egg smell.
Hi everyone, hoping I can get some guidance on this issue before I dig into it. This is a 2003 Discovery 2 se 4.6l.
I have a CEL with code 0130 on the ultra gauge. I have replaced the b1s1 o2 sensor and I am still getting the same code. The sensor seems to be going through its normal cycle, starting at 1.000 but drops continuously until it reaches 0.000. I have not swapped sensors from side to side, but based on the o2 sensor cycling correctly I don’t believe the new sensor is bad.
Symptoms:
*Rotten egg smell during cold start.
*Bank 1 cat is getting significantly hotter than bank 2 (350f vs 270f when checked).
*Very very slight rough idle.
Replaced the head gaskets roughly 6 months ago. Truck has run great ever since. Could the upper or lower intake bolts have lost torque causing a vacuum leak? Possibly bad injector o rings? Could this be a bad fuel purge valve?
I’m thinking the cause may be a physically damaged injector dumping fuel due to the smell and cat temps.
I would love some guidance from anyone who may be able to help.
Thank you!
Old Oct 6, 2024 | 02:27 PM
Jefe's Avatar
Bump. Anyone?
Old Oct 6, 2024 | 03:46 PM
DiscoBuckeye's Avatar
Originally Posted by Jefe
Bump. Anyone?
Are your Cats rattling? I'm guessing a piece broke free and has blocking the exhaust. Hit them with the heal of your hand or a rubber mallet
Old Oct 6, 2024 | 08:00 PM
Extinct's Avatar
Yes, intake bolts could be loose, I recommend checking them. They will do exactly what you are seeing.
Old Oct 8, 2024 | 04:47 PM
Jefe's Avatar
I haven’t heard anything, but I will check!
Old Oct 8, 2024 | 04:48 PM
Jefe's Avatar
The upper intake correct?
Old Oct 8, 2024 | 05:29 PM
Extinct's Avatar
No, lower.
Frank4
May 27, 2023 09:10 PM
girouardrover
Mar 23, 2023 08:28 AM
bcolins
Sep 19, 2013 07:40 AM
sorusty
Dec 17, 2010 12:16 PM
tango123
Sep 23, 2010 07:17 AM
