Code P0130 - o2 voltage dropping to zero, rotten egg smell.
Hi everyone, hoping I can get some guidance on this issue before I dig into it. This is a 2003 Discovery 2 se 4.6l.
I have a CEL with code 0130 on the ultra gauge. I have replaced the b1s1 o2 sensor and I am still getting the same code. The sensor seems to be going through its normal cycle, starting at 1.000 but drops continuously until it reaches 0.000. I have not swapped sensors from side to side, but based on the o2 sensor cycling correctly I don’t believe the new sensor is bad.
Symptoms:
*Rotten egg smell during cold start.
*Bank 1 cat is getting significantly hotter than bank 2 (350f vs 270f when checked).
*Very very slight rough idle.
Replaced the head gaskets roughly 6 months ago. Truck has run great ever since. Could the upper or lower intake bolts have lost torque causing a vacuum leak? Possibly bad injector o rings? Could this be a bad fuel purge valve?
I’m thinking the cause may be a physically damaged injector dumping fuel due to the smell and cat temps.
I would love some guidance from anyone who may be able to help.
Thank you!
Symptoms:
Thank you!
I haven’t heard anything, but I will check!
