Code PI301 or P1301
RE: Code PI301 or P1301
ok. If you haven't changed plugs recently then do that and replace the wires too. 8mm Magnacore seems to be what the experts on this forum stand by.
If you've never changed plugs before start by hand tightening then to torque specs.
If you have done lots of plugs then apologies for stating the obvious
Actually, I have no clue how much torque I should use. Would you be so kind to enlighten me with that information please? I still don't know how/if I can get behind the engine to install the wires. It looks mighty tight. I'll be optimistic and keep telling myself others have done it, I should be able to as well.
Is therea trick to this? Certain easy parts that I can remove to assist with accessability?
It is a basic DIY, but your right its tight. Just take your time, maybe do half one day half the next. As for torque 20 Nm (15 lbf.ft)
As for plugs, for the 4.0 use Champion RC11 PYP B4 and for the4.6 use Champion RN11 YCC
I think Champion 322/RN11YC4 will also work. These are one option, just search plugs on this site as you will find many discussions about others (bosch etc.) opinions vary widely.
DiscoBenjamin
10-14-2011 05:53 PM
