Code reading translations
Old May 5, 2009 | 04:26 PM
aublec22's Avatar
can i down load the rave cd on a MAC computer? it is intel based
Old May 5, 2009 | 06:04 PM
Yes, just know going in, this is a huge PDF file, course you may use it every week for all the information it contains.
Old May 6, 2009 | 11:56 AM
aublec22's Avatar
Thanks i will do
Old Sep 2, 2011 | 11:27 AM
ajboardman82's Avatar
4th Gear
Mike,
I had a bunch of codes come on my Discover 2. They are as follows (I have posted what I think the cause is):
P0455 - Check Engine - Caused by one of these other issues
P1590 - Caused by 3 amigos - ABS (how can I fix the damn annoying 3 amigos)
P0560 - System voltage malfunction - bad Battery?
P1536 - AC? or caused by something else?
P0650 - Bad dash light?
I think I may have two main issues, and I am yet to have the battery checked. I am headed there after I post this. Hopefully its battery, but if not, anything else I should look for?
And any advice on killing the three amigos is welcome.
Old Sep 2, 2011 | 11:35 AM
4th Gear
Also forgot to mention - the truck hesitated starting up the other day, but hasn't done so since. It is also in "limp mode", which I think is just a default so you dont cause further damage.
Old Sep 2, 2011 | 12:21 PM
jafir's Avatar
If it was hard to start, check out your battery/cables/alternator/charging system first before worrying about those codes. After getting the power straightened out, clear the codes and see if they come back.
Old Sep 2, 2011 | 02:30 PM
Originally Posted by ajboardman82
Mike,
Next time don't start a new issue on a near 3 year old thread.
Go to a local parts store and have your charging system tested/fixed and then get the codes cleared and see what comes back.
The 1590 will come back, 3 amigos.
Old Nov 1, 2011 | 12:55 PM
mtnguy1969's Avatar
Smile P1510 Idle Air Control Valve Fault...Help!
Can anyone answer a question for me? I Replaced my Idle Air Control Valve(IACV) and the engine still idles rough. Had the engine code reading: "P1510 Idle Air Control Valve Fault opening Drive Cycle A: signal missing". In addition the hill decent control illuminates sometimes. I dont see how they could be related. I am just driving it on road. Thanks for any input or suggestions.
Old Dec 12, 2011 | 07:46 PM
rimasco's Avatar
hey guys.. i have a couple of codes that i just cleared and waiting to see what comes back.. I recently had some voltage issues so I cleaned up the some grounds and replaced and rerouted the sepentine belt that previous owner screwed up.. Im curios if any of these codes are related.. i know ones MAF and and another pertains to evap.. well, here goes..
P1562
P1884
P0327
P0455
P0102
sayeedA
Nov 15, 2011 11:02 PM
tweakrover
Jul 2, 2010 01:47 PM
rover
Freelander
Apr 28, 2008 08:42 PM
leadoverdistance
Nov 20, 2007 05:06 PM
