Code time-will it hurt the wallet?
Old Nov 17, 2005 | 10:06 PM
MEP's Avatar
MEP
Default Code time-will it hurt the wallet?
Got these -P1178.....P0300.....P1316.....P0308....P304. The printout says fuel air metering for 1178.Misfire on #8(P0308)misfire on #4(P0304)Random misfire for P0300.P1178 says "amfr correction at maximum positive value"[:@]I don't get the last one.I'm sitting down with my calculator awaiting bad news[sm=smiley11.gif]I have to say that I really like this site.I have been doing alot of searching in the archive to learn more-so as not to look like a dumb newb.I have auto experience-just not with the OBDII system.Once I have enough jack to "afford" a manual,I will tackle alot more concerning my rig.If you folks could help me out-I'll buy the first round[sm=icon_cheers.gif]
Old Nov 17, 2005 | 10:24 PM
MEP's Avatar
MEP
Default RE: Code time-will it hurt the wallet?
Oh-forgot to mention I did a tune-up(new wires,plugs).No difference,although it needed it done any way.
Old Nov 18, 2005 | 12:39 AM
mikemeyer0's Avatar
did you get the codes after you did the tune-up?
Old Nov 18, 2005 | 08:33 AM
MEP's Avatar
MEP
I had the codes before-but it still misses at idle.I will go back to Advance Auto and have them erased.I'm sure most will return,then I'll repost my findings.Thanks Mike......
ORIGINAL: mikemeyer0
Old Nov 26, 2005 | 11:56 AM
Hank's Avatar
P-1179 is also common for a O2 sensor going bad. Could be related to the other problems too. You need to have the system plugged into a Rovercom or Autolodgic computer to determin which O2 sensor may be going bad. The handheld OBD-II systems do not tell you this information. Or, the software from OBD2.com may help out if you wanted to buy a low budget system...
Old Nov 27, 2005 | 09:44 PM
MEP's Avatar
MEP
Thanks Hank-I had a gut feeling it was related to an 02 sensor.Although, after looking at the prices for replacement(s)[sm=smiley35.gif]I was afraid to admit it.Any "cheap" sources for O2's you guys/gals may know of?I can see there are 2-is there a third I can't see?
Old Nov 29, 2005 | 12:22 PM
Hank's Avatar
Might try Nathan. http://www.discountbritishparts.com/...I/disco_i.html
jpluncford21
May 21, 2011 06:19 PM
aussiedg87
May 4, 2011 08:05 AM
georgep
Oct 1, 2010 07:00 AM
tornado_735
Apr 24, 2009 07:33 PM
sopjih
Oct 2, 2006 04:43 PM
