Codes after oil change and coolant work.
Old 11-28-2010, 07:21 PM
buick215's Avatar
Thanks for the help, guys. What had me worried was that this was the first time that I actually attempted to do something other than routine oil changes and filling the tires with air. When I felt the rough idle and saw the check engine light come on I said to myself maybe I should have had a mechanic replace the hoses, flush the coolant system, replace the thermostat and even do the oil change. I guess it was just a coincidence or maybe the connection got oil from a previous oil leak coming from the passenger side valve cover gaskets and decided to fail the day after I repaired the cooling system and performed an oil change. I have since learned, thanks to this forum, to tighten the valve cover bolts at every oil change interval.
Old 11-28-2010, 07:43 PM
GARovee's Avatar
That pass side valve cover oil leak is exactly why the sensor we're talking about fails.. Oil soaks it and the connector.
Old 11-28-2010, 07:59 PM
buick215's Avatar
Well I'm glad it was the valve cover gasket and not me. I guess this gives me confidence to tackle the next project, removing and painting the headliner. Going back to the oxygen sensors do I need a special socket or wrench and should I use anti-seizing grease.
Old 11-28-2010, 08:01 PM
Your truck is going to be very happy with this change and you will save a ton of money.
Old 11-28-2010, 08:07 PM
buick215's Avatar
Good to hear. I also used a high capacity oil filter for the first time, Mobil 1 301 I believe. I use to use the Mobil 1 short filter. Pretty soon it will be cheaper for me to fly in a private jet.
Old 11-28-2010, 08:36 PM
GARovee's Avatar
No special socket.. Just be sure to soak the threads in penetrating oil the day before you try changing it if it's rusty.
Old 11-28-2010, 08:45 PM
buick215's Avatar
Will do, even though the previous oil leak probably took care of that for me. Do you happen to know who has the best prices on those oxygen sensors.
Old 11-28-2010, 08:53 PM
GARovee's Avatar
Atlantic british.
Old 11-28-2010, 08:54 PM
buick215's Avatar
Thanks
Old 11-29-2010, 10:10 AM
Try Amazon as well.
Paul3221
11-25-2013 12:12 PM
Freebie_Oslo
Freelander
06-17-2013 02:48 PM
drewski
05-31-2013 10:50 AM
collin Barrows
08-28-2011 07:13 AM
tito5590805
10-04-2010 09:11 AM
Quick Reply: Codes after oil change and coolant work.
