Codes are driving me nuts!
Old Mar 8, 2016 | 11:57 AM
RawFaith's Avatar
Default Codes are driving me nuts!
It all started when I decided to pressure wash the engine bay to get rid off all the old dirt and oil spots.
Took it to the shop and they clear all the countless codes.
After that the check engine light came on days later.
Based on that I decided to get a wifi code reader and to download the DashCommand app.
3 codes keep coming back and you can definitely feel the truck running rough when the light comes on.
So before buying parts blindly, I much rather ask for wisdom.....
Pics and codes coming soon
Old Mar 8, 2016 | 11:59 AM
acamato's Avatar
Torque is another good app for reading codes and looking at live OBDII data.
Old Mar 8, 2016 | 12:04 PM
RawFaith's Avatar
here are the codes!!!!
Old Mar 8, 2016 | 12:25 PM
chubbs878's Avatar
Hey get something that puts off smoke or vapor, or spray brake cleaner around hoses and connections to check for vacuum leaks around the engine. A hose and/or hoses may have come loose/cracked/broke. Hook up your reader and check the values switching between the O2 sensors, clean the MAF sensor.
Old Mar 8, 2016 | 01:33 PM
cappedup's Avatar
1590 can be wheel speed sensors. If you've pressure washed them, maybe the plugs need undoing, spraying with wd40 and putting back together.
The others I believe can be due to leaks. Look up smoke testing.
Snafu / Disco Fries
Aug 25, 2014 07:26 AM
dcarr1971
Feb 8, 2013 08:16 AM
wilson96rr
16
Dec 22, 2010 06:52 AM
wilson96rr
Dec 14, 2009 08:44 PM
lajilana
Jul 17, 2006 10:35 AM
