Codes and idling funny... Point me in the right direction!
Old Feb 3, 2019 | 11:06 AM
cfairless's Avatar
Default Codes and idling funny... Point me in the right direction!
Hey guys! Started throwing a few codes and idling funny..... P1171, p1590, and p1174. From research, I'm leaning toward MAF sensor but thought I'd stop by here for any talk about experiences and advice! Seems to be fine when I'm on the gas but doesn't idle smooth sitting still. Got a little hitch in it's giddy up... TIA for any ideas!
Old Feb 3, 2019 | 04:51 PM
Richard Gallant's Avatar
Check for vacuum leaks, loose hoses. Any kind of of leak or loose hose can cause the 1171/1174 codes. The P1590 is a rough road code not sure why that is showing up.
Old Feb 4, 2019 | 02:53 AM
The Deputy's Avatar
Yes, check for vacuum leaks and inspect intake hose/tube between MAF and throttle body for loose connections. MAF would also be suspect. Check your air filter too, while your in there.
​​​​​​​ Brian.
cybercop
Jul 17, 2019 05:42 PM
Nysptsman
Jun 28, 2017 05:52 PM
srockrae
Jan 31, 2013 07:44 AM
seamuspg
Apr 5, 2011 08:50 AM
jkid
Nov 29, 2008 04:48 PM
