Codes P0159, P0160, P0161 ???
Old Apr 1, 2009 | 07:54 AM
jycsalas's Avatar
Default Codes P0159, P0160, P0161 ???
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2
Before I go replacing this/these on my friends 04 Disco... could there be something else causing the codes?
She already has the O2 sensors as a "local mekanic" told her the rig needed them.
Bank 2 is the passenger side and sensor 2 is the farthest from the engine right?
Thanks,
Josh
Old Apr 1, 2009 | 10:15 AM
okdiscoguy's Avatar
So the mechanic replaced them? I would take it back.
You are correct on the location. Might want to check the plugs.
Old Apr 1, 2009 | 10:21 AM
What brand of 02 was installed, were all 4 replaced?
Could be a connection issue or a wire harness issue, could just be a bad 02.
Old Apr 1, 2009 | 10:22 AM
jycsalas's Avatar
NOT installed. she just bought them and has them in hand. She has the original sensors still in. Her disco has about 35k.
She has only two of them. I dont know which two. I think they are the front two, I haven't seen them to confirm.
She ordered them from a LR dealer in Florida. So OEM....
Old Apr 1, 2009 | 11:00 AM
redhotbuzz's Avatar
sounds like a connection prob clean and dielectric connections. Even if and when you replace O2s
Old Apr 1, 2009 | 02:09 PM
jycsalas's Avatar
will try that!
dusty1
May 30, 2014 10:31 AM
madadam2020
Sep 7, 2011 08:43 PM
madadam2020
Sep 7, 2011 08:13 PM
RedAustinIX
Jun 7, 2011 11:25 AM
hriant88
Apr 30, 2008 07:33 AM
