Codes P0446, 0327 and code 1174
I have a 2000 Disc 2 with 174,000 miles new O2 sensors. But I知 now getting three new codes P0446, 0327 and code 1174 does anyone have a clue where I should start .
I put in new plug wires and plugs and coil pack in Oct last year. And I only use 91 or better octane gas. The check engine light only comes on when I知 at idle
This is the frist time that I have ever posted anything so I have not done the best job of it. I did post this the other day and Dico Make's reply was the 446 is a vent control issue with the Evap system, the 327 is a bank 1 knock sensor and the 1174 is a rich run on both heads.
When was it last tuned along with plug wires, what octane gas are you running?
Halftrack99
07-25-2015 10:52 AM
