Codes P0741, 0734, and 0722
Old Feb 15, 2009 | 03:14 PM
skunkridge's Avatar
6th Gear
Default Codes P0741, 0734, and 0722
I'm back, 15 mos. later. Finally got my 2000 disco plugged in and got p0741 (Torque Converter CKT Performance or stuck off), p0734 (Gear 4 Ratio Incorrect), and p0722 (Speed Sensor No Signal). Symptoms: It will not move forward at all, it will only move in reverse when in low range. Battery putting out a consistant 14+ volts. M and S lights flash when you try to put it in any forward gears. when shifter is in 1 or 2 position the little red lights that are normally beside the shift lever stay by the D and blink. Any thoughts on what the fix could be, involve, etc.. Thank You
Old Feb 15, 2009 | 04:17 PM
Check with a tranny shop, sounds like the XYZ switch on the tranny has failed.
Old Feb 15, 2009 | 04:30 PM
And yes, the XYZ switch is a real switch, they couldnt come up with a real name for it I guess.
If it is not that then it is the MAF.
Old Feb 15, 2009 | 07:10 PM
roverguy7's Avatar
check your tranny fluid, xyz switch will cause it to run bad and not shift right, but itll still move, it sounds like your fluid is real low, either that or you have some clutch issues
Old Sep 17, 2024 | 03:45 PM
Brettsvn's Avatar
I know this is a long shot being that this thread is so old, but did you happen to get any resolution? I’m having the same three codes and same symptoms
Old Sep 17, 2024 | 04:43 PM
Harvlr's Avatar
Maybe try the things posted above. If your issue continues, you should make a new post.
Old Sep 17, 2024 | 05:47 PM
Brettsvn's Avatar
Yeah I’ve already done everything listed about minus taking it to a shop. Replaced trans oil and filter, battery and grounds are good, I’m going to clean the maf and put the XYZ switch back together but the switch looks brand new inside so I highly doubt that is it. Trying to get ahead of the curve here and ask someone with the same exact scenario what their resolution was. And if I don’t get a response and it doesn’t work when put back together, then I will make a new post.
dogandpony
Jul 18, 2022 02:40 AM
meltdowndave
Apr 28, 2019 09:53 AM
TRIARII
Mar 7, 2018 10:36 PM
kman35ca
Aug 7, 2012 06:35 PM
Dead One Me
Feb 12, 2012 10:34 AM
