Codes showing up
Old Nov 28, 2007 | 05:58 PM
sfxgamer's Avatar
Default Codes showing up
p1194-oxygen sensor heater circuit high resistance, downstream sensors---p1191-oxygen sensor heater circuit open circuit, donstream sensor
How many o2 sensors does the 96 discovery have? where are the ones from the code showing up located? Any help is appreciated.
Old Nov 28, 2007 | 07:18 PM
Default RE: Codes showing up
On a 96 Disco, you have 4 02 sensors and ig you are over 100,000 miles, you should change out all 4 sensors which will improve your engine performance quite a bit.
philander
Aug 19, 2011 04:20 PM
JEFIII
Sep 9, 2010 11:16 AM
MrBrooks
Jun 11, 2010 09:25 PM
sfxgamer
Aug 17, 2007 09:05 AM
