Coil pack mounting screws. FINAL STRAW for shady Indy.
Wow my Indy is SHADY SHADY SHADY!!! I put my kid's truck in shop for head gasket, water pump and plugs and wires. Mainly because I didn't have the time to get up to speed to undertake the HG job. I get the truck back and the following things I discovered. Oil fitting was not snapped on and I lost 5.5 quarts of oil instantly all over right side of engine bay. This happened the day after I got it back. I got that cleaned up. Next, I noticed exhaust leak and he said don't fix it because it would be leaking withing the month. I hate noises, so I taught my son how to change the gaskets and it is now quiet. Tonight, I was sitting at the light and noticed rough idle, SES light on and it steadily got worse like it was running on 7 cylinders. I get home to start checking plugs to find the culprit and when I pulled plug wire off of the #4, the diode was still on the plug. So now I am pissed because only about 500 miles on plug wires. Last straw, remember this shop JUST CHANGED MY PLUGS AND WIRES. I was removing the wires from coil packs and I find the fricken coil pack just effing sitting behind intake, not bolted down. I have been trying to track this little rattle down and I bet a dollar to donuts that this is the dang rattle I have been chasing.
I need to by the mounting screws and need to confirm if they are M6 X 12mm. Can you tell me 8f this is correct?
a good set of wobble extensions are very useful. Also a telescoping magnet. Made bolting/unbolting coils much simpler.
