Coil pack mounting screws. FINAL STRAW for shady Indy.
Old Apr 17, 2016 | 12:23 AM
lr3_ovrlnd3r's Avatar
Default Coil pack mounting screws. FINAL STRAW for shady Indy.
Wow my Indy is SHADY SHADY SHADY!!! I put my kid's truck in shop for head gasket, water pump and plugs and wires. Mainly because I didn't have the time to get up to speed to undertake the HG job. I get the truck back and the following things I discovered. Oil fitting was not snapped on and I lost 5.5 quarts of oil instantly all over right side of engine bay. This happened the day after I got it back. I got that cleaned up. Next, I noticed exhaust leak and he said don't fix it because it would be leaking withing the month. I hate noises, so I taught my son how to change the gaskets and it is now quiet. Tonight, I was sitting at the light and noticed rough idle, SES light on and it steadily got worse like it was running on 7 cylinders. I get home to start checking plugs to find the culprit and when I pulled plug wire off of the #4, the diode was still on the plug. So now I am pissed because only about 500 miles on plug wires. Last straw, remember this shop JUST CHANGED MY PLUGS AND WIRES. I was removing the wires from coil packs and I find the fricken coil pack just effing sitting behind intake, not bolted down. I have been trying to track this little rattle down and I bet a dollar to donuts that this is the dang rattle I have been chasing.
I need to by the mounting screws and need to confirm if they are M6 X 12mm. Can you tell me 8f this is correct?
Old Apr 17, 2016 | 09:05 AM
coors's Avatar
I just referenced RAVE but could not locate any mention of "size" of bolt.
Here are some images that may help.
Worse comes to worse, use high quality zip ties.
As far as the rattling goes, this could potentially be the culprit.
Old Apr 17, 2016 | 09:12 AM
jamieb's Avatar
Web search says m6x1.0
a good set of wobble extensions are very useful. Also a telescoping magnet. Made bolting/unbolting coils much simpler.
Old Apr 17, 2016 | 09:16 AM
Originally Posted by jamieb
Wish I knew the size but a good set of wobble extensions are very useful. Also a telescoping magnet. Made bolting/unbolting coils much simpler.
It is, in fact, M6 X 12mm. I hate half a$$ work.
Old Apr 17, 2016 | 10:03 AM
batard's Avatar
My notes say they're 8mm head bolts securing that coil bracket to the upper intake manifold, assuming that's what you're talking about.
gbob
Sep 29, 2013 02:03 PM
pinkytoe69
Apr 18, 2013 01:00 PM
Spencerfitch
Sep 26, 2012 05:39 AM
jpmiller
Jul 24, 2012 07:02 AM
Eak69
Jun 13, 2010 11:37 AM
