Coil pack and wires and plugs.
landroverdude (08-17-2020)
The following 2 users liked this post by Discorama:
Best4x4 (08-17-2020),
Are you having ignition problems or are you doing this just to be doing this? I recently did all of the top end rebuild on my V8 with SAI and I'm glad I did it.
BTW... don't forget if you are removing the IM, purchase the Fel-Pro upper intake plenum gasket #MS97221. Also, maybe think about replacing the aging 8 injectors with new o-rings and the Fel-Pro rocker cover gaskets #VS50789R if they are leaking.
Richard Gallant (08-18-2020)
I just got my truck back from the mechanic I use. Had the spark plugs, wires and one injector replaced. $550 labor. Was a little surprised but I attempted the job and quickly realized in the 90 degree sun I’ll just pay. Engine was missing very badly. Blinking check engine light. It’s like my truck was getting back at me for not using for 10 days.
