Coil Question
Old Mar 29, 2019 | 08:43 PM
Lisa Bunch's Avatar
Default Coil Question
I removed my coils to clean under and behind them, and to search for 2 missing bolts from PO repair. The connector for the left bank coil was not locked on and came right off. I think that was my problem. Anyway, someone has replaced one of the coils, because they are both marked 1-2-3-4. Nigel is original and if I remember right has one side marked 5-6-7-8. I looked at the coil map in my shop manual and they were wired correctly. Does anyone know if they are all marked 1-2-3-4 now?
I have the vertical bolts for the plenum, but the horizontal ones were missing.
Thanks Lisa
Old Mar 29, 2019 | 09:00 PM
Best4x4's Avatar
All the coils are marked 1-4 (some other vehicles that use the same coils are only 4 cylinders). I don’t have an OEM Bosch to look at off hand, but all the aftermarket units are labled 1-4.
Old Mar 31, 2019 | 10:42 AM
bcurtman's Avatar
Lisa,
I know you are more knowledgeable and capable than most, but want to throw this out there to make sure "1-4" doesn't indicate anything to do with wiring.
Old Mar 31, 2019 | 03:35 PM
CollieRover's Avatar
Thanks Lisa
on mine there is only two bolts to hold it to the upper intake, and a clip that is long gone, so mine is on with just the 2. It’s an ‘03
the shop who did my Turner short block, didn’t even bother to bolt it in.
Old Mar 31, 2019 | 04:36 PM
Lisa Bunch's Avatar
Yeah, I don't see the purpose for the other 2, they talk about them in the AB video. I just need to be sure I get the right length of wires in the right place.
Old Mar 31, 2019 | 10:02 PM
mollusc's Avatar
my '03 has four bolts for the coil bracket, just like my '99 does.
i know that i've read on several misfire threads on this forum that one of the causes seemed to be that the coil bracket wasn't bolted down properly.
Old Apr 1, 2019 | 02:51 AM
JUKE179r's Avatar
Is the bottom of our coil packs grounded to it's mount bracket?
Old Apr 1, 2019 | 06:34 AM
mollusc's Avatar
that seemed to be the conclusion, yes.
Old Apr 2, 2019 | 10:00 PM
bcurtman's Avatar
My eBay coils did not sit down flush in the mount. I remember grinding some clearance to improve the fit, but not sure they are sitting tight enough to ground. This could be a problem if that is in fact where they ground. I'll have to look. Maybe the screws ground them without the bottom touching metal to metal?
GCBurke
May 8, 2019 10:16 AM
Jeff Blake
Jun 30, 2016 09:13 PM
Hword_39
May 13, 2016 08:45 AM
Colorado David
Jan 21, 2014 06:13 PM
randyt777
Nov 30, 2011 07:06 AM
