Coil spring conversion
Old Apr 26, 2011 | 06:30 AM
DiscoIIBrandon's Avatar
Originally Posted by Landy Idaho
kcabpilot, my problem is that my rear airbags keep deflating and because they are so expensive I want to switch over to the hassle free coil spring suspension. The only thing stopping me from doing it right now is that I am not sure on how to handle the compressor once I have converted to spring.
I know that i'm never putting the system back in and messing with it, and that is highly unlikely that I'll ever sell it someone that would pay me a little more if I left the parts there so they could bring it back.
So, just take the compressor out. You'll still want to pull the underhood fuses and relays related to SLS (1 of each I believe) and you'll have the SLS light on your dash (unless you want to pay a dealer or someone with testbook/t4 $80-$170 to reprogram your truck to coils). However, its as easy as taking off the 2 screws holding the cover on, removing the 2 bolts holding it in place, and disconnecting the 3 electrical connectors and 2 or 3 air lines. Zip tie the remaining lines up and out of the way and you're done. Now you've lost some extra weight and can sell the compressor. My .02
But yes, if you can easily save your system and can afford it, keep it.
Old Apr 26, 2011 | 06:48 AM
drowssap's Avatar
A testbook or Hawkeye is needed to shut off the SLS warning lights after you unplug the compressor, you just have to change the BCU to read you truck as a coil spring unit instead of a SLS equipted unit.
Old Apr 26, 2011 | 05:23 PM
Landy Idaho's Avatar
Just to clarify, I can disconnect my compressor and the only problem will be that I will have the SLS indicator light up on my dash but not actual problem existing, correct?
Old May 22, 2011 | 12:27 PM
redwhitekat's Avatar
what would the cost be to buy the parts to replace the air suspension ? im assuming all four springs have to be done ?
Old May 22, 2011 | 04:48 PM
mwindth's Avatar
Nope, only rear: Land Rover Discovery II Rear Air Suspension & Coil Spring Kit - Land Rover Parts & Accessories At Atlantic British
Why not buy a truck without it to begin with? Are you looking for a 7 passenger?
Old May 22, 2011 | 05:26 PM
well most in my area have the air suspension, havent seen any with springs
Rev Den
Jul 11, 2012 12:35 PM
b_woodroaster
Nov 5, 2010 08:54 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
lonely king
Aug 5, 2008 02:26 AM
HKROVER
Aug 19, 2007 06:00 AM
