Coil Spring Spacers
Old Feb 17, 2020 | 07:53 PM
chandlerhayes01's Avatar
Default Coil Spring Spacers
I have a question that I might get roasted for but I'm going to ask.
I have a 2003 DII that I mostly take on fishing trips and around town. I was wanting to do a couple inches of lift on it. I've seen some adds for coil spring spacers, is this a good option for a light wheeling DII?
Thanks
Chandler
Old Feb 17, 2020 | 08:25 PM
Alex_M's Avatar
Yes, as long as they are the type that actually raise the spring perch, they are perfectly acceptable.
Old Feb 17, 2020 | 08:39 PM
is there particular brand that is recommended?
Old Feb 18, 2020 | 08:47 AM
whowa004's Avatar
The lucky8 1" spacers are all I've had experience with and are a nice piece.
Old Feb 18, 2020 | 11:17 AM
Alex_M's Avatar
Theoretically they'll all work the same. One thing to note is on the rear you may want longer shocks or to extend your shock mounts so you are not limiting yourself on down travel.
Old Feb 18, 2020 | 11:28 AM
whowa004's Avatar
agreed. I would not run spring spacers on stock shocks.
Old Feb 18, 2020 | 09:07 PM
XRAD's Avatar
plenty of 2" lift kit options. Read up on front driveshaft upgrade and front caster rod degrees. Good stuff to know.
Jakerover
Apr 8, 2018 09:49 PM
elboy0712
Nov 5, 2017 11:07 AM
03discoken
Nov 29, 2016 08:59 PM
ZGPhoto
Mar 19, 2013 11:32 AM
toofaroffroad
Jan 22, 2012 10:55 PM
