Coil under the coil packs?
Old Sep 29, 2014 | 07:46 PM
04duxlr's Avatar
Good thing you posted. If that side had no restriction in it you would have been smoking pretty good after you put it back together and had some messed up vacuum in the intake. Nice to have caught before you reassembled all those pieces.
I can't believe that they put such an easily plugged piece in such an inaccessible location. As far as I can tell, the valve cover has to come off to get to that. Maybe that tube can be pulled out of the valve covers but mine didn't seem to want to budge. I had the valve cover off anyway so I didn't try too hard but it must come out. $40 in gaskets and 3 hrs. of effort to clean up a $5 part seems crazy even for LR.
Old Sep 30, 2014 | 11:33 AM
drowssap's Avatar
the 99-02 can be pulled up from the top with needle nose pliers, if your luclky
Old Sep 30, 2014 | 01:50 PM
slabrat's Avatar
Might help to pull it occasionally and clean it so it doesn't get stuck? I have not done this but maybe I will tomorrow.
Old Oct 1, 2014 | 07:24 AM
trialrun's Avatar
yeah, no kidding. On the 03-04 models the brass fitting is capped off. Must be pressed in b/c I couldn't get it off for the life of me. Got to love the engineering on this thing
Old Oct 2, 2014 | 05:25 AM
04duxlr's Avatar
I think if you cut the tube in the middle and pulled it apart when you put it back together inside the hose an extra clamp would keep it in place and functioning.
Old Oct 2, 2014 | 09:23 AM
RicketyTick's Avatar
03/04 comes out from the bottom with the valve cover off and the baffle removed. I have never been able to get the cap off of the tube.
Since you are probably needing new valve cover gaskets anyway just put a new pcv in then.
or if you just need a quick fix you may want to try spraying carb cleaner or brake cleaner into the small hole in the cap and let it sit for a bit then put a little air into the hole and see if will go through. If it's not too bad it may go through.
Old Oct 2, 2014 | 07:19 PM
borchera's Avatar
On our 2003 I have been able to use slip joint pilers and twist the tube out of the valve cover. The tube is a press fit but does come out of the valve cover to allow your to remove the oil separator.
2003 Discovery 144K
Old Oct 2, 2014 | 09:57 PM
04duxlr's Avatar
2003 Discovery 144K
I figured it could come out with enough effort. Still a pretty crappy design if you ask me. Maybe if you found a compression fitting that fit it you could tighten that on it and then use a wrench to turn it out. That way you wouldn't risk crushing it.
Old Oct 2, 2014 | 11:30 PM
I tried to get a few out from the top and gave up. I have even tried attacking it from the bottom, with the VC off, taking a pin punch the size of the inside diameter of the tube and knocking it out of the top with no luck. I'm sure the tube will come out because it went in but, I was afraid I would wreck the tube. Glad to hear someone had luck with that.
Old Oct 13, 2014 | 06:06 PM
trialrun's Avatar
So a little update, ended up pulling the heads and I'm glad I did. Cylinder four (where I had the misfire) was so gunked up in the valve seats and on top the piston. Going to go ahead and pull the timing chain, update the oil pump, clean the oil pickup, new gaskets and check the water pump. Heads are currently at RPE machine shop in Hartford ct
Before and after cleaning the rocker covers
New parts
I need a bigger garage
Oil in the hose coming from the pcv tube
Cylinder four
